Hi everyone, I've got a bit of slight problem. I'm currently building my second computer, I'm working with a a Asus M4A89GTD mobo with a AMD Phenom II 965. I've installed the cpu correctly and lowered the locking lever. However, when trying to remove the cpu the lever does not fully extend and only goes to about 2/3's of the way. This means I can't remove the cpu as I wish to change the heatsink.
I'm slightly worried that I've some how managed to bend some pins and caused the cpu to become stuck, I'm 100% certain that I've installed it correctly and matched up the triangle on the cpu with the triangle on the socket.
Any help would be very much appreciated.
Thanks.
Thanks.
