Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Memory > Memmory problem ' dead motherboard
Forum Motherboards & Memory : Memory Memmory problem ' dead motherboard
Hello,
im new here and my english is pretty bad . so im sorry for that hope you can understand me
recently i inserted one memory stick of 2gb ddr2 into an DH55PJ 1333mhz mother board
as soon as i turnd on the computer there were 3 beeps pause and agian , some i placed back the original ram [2 sticks of 2 gb ddr3 ram] and it kept on beeping i searchd all over the internet and realized that that the beeping means that theres a memory problem
now both computers [the one i took the ddr2 ram and the one with the dh55pj have the same problem - the screen and the keyboard dosnt light up
my motherboard is DEAD?
specs
first computer
E6300 2.8 ghz
1 stick of kingstone ddr2 2gb ram
intel dg31pr
9500gt 1gb oc'd
JTC 500w
second computer
core i3 540
DH55pj
2 sticks of 2gb ddr3 ram kingstone
sunpro 400w
ps- all worked just fine before i changed ram -
i tryd already to
remove and reseat the cmos battry
all possible ram seats
checkd wiring all appears to be fine
at my first system - i removed all psu cabels from my mother board and place them agian
thanks hope youll understand me
Message edited by wickreD on 01-29-2011 at 12:36:22 PM
Reply to wickreD
You probably damaged the ram slot on your DH55DJ board by trying to use ddr2 in a ddr3 slot. Too bad you didn't come to us first before using the wrong ram.
Reply to o1die
- 0 +
i got the same problem on both computers
and i try'd to use other ram slots still - not work
Reply to wickreD
I woulden't doubt if you shorted the RAM as well when you placed them in the slots, they're very sensitive pieces of hardware.
Overall that's a pretty sticky situation, either mobo or RAM damage (wouldn't doubt both either). I would take it into a local shop and see if they can diagnose it for you, considering you don't want to buy another stick of RAM and *possibly* burn that one too.
Message edited by Antikythera013 on 01-29-2011 at 09:45:27 PM
Reply to Antikythera013
i resently did this you can do this
open up your case and pull the cmos battery out. It is a quarter size batter like you put in your watch. Push the metal clip and the battery will pop out keep it out for about 5-10 sec then put it back in. Then start your system this is going to reset your cmos withch after doing so the computer will boot up with a beep or 2 caint remember. Then it is going to ask if you wont to continu or enter setup "bios" select continu. By pushing the key reqester and then seleck start windows normaly or start windows with last known good config. There done let me know how it goes
like i said i whent thru the same issue but i whent in and changed how much power whent to my dimms "ram slots" and it shut down and did the same 3 beeps and no moniter no keyboard no mouse give it a try
lynmachine
Reply to lynmachine
sorry didnt read you triid this already sorry
Reply to lynmachine
- 0 +
So you tried to put DDR2 into a DDR3 board?
Reply to kilo_17
if you reset your cmos
and still nothing cheack the ram look for burnt spots or cracks in the modals
also i belive ddr3 and ddr2 have dif notches how did you get them in did you force them in if you did you may have screwed the rams up by braking them try buying a cheap ram modual and puting it in like if its ddr2 ram buy the same kind buy the ddr2 and make sure the speeds are the same and try it out
Reply to lynmachine
ya i just checked thay are diff notches you had to of forced them in upload a pic of the ram fo me and post the link here plz i need to see them ty
here look at the dif between ddr3 and ddr2 notice the diff notches
http://gamingpcguide.net/article/ddr3-vs-ddr2
Message edited by lynmachine on 01-29-2011 at 10:42:09 PM
Reply to lynmachine
- 0 +
Yeah if you forced them in completely you probably ruined RAM and possibly the motherboard
Reply to kilo_17
- 0 +
i didnt forced it , i was sure that the ram is in but it was not , i realized it only after i turnd on the computer , so i turnd the computer off and switched it back the way it was before
btw thanks all helping me
Reply to wickreD
- 0 +
past few days.....
Reply to wickreD
- 0 +
Okay, so you didn't force them in?
Reply to kilo_17
- 0 +
yes im sure i didnt forced them in
Reply to wickreD
- 0 +
Still not working?
Reply to kilo_17
- 0 +
Intel DG31PR - http://www.intel.com/support/mothe [...] 027918.htm
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
4 GB maximum total system memory using DDR2 667 or DDR2 800 DIMMs
Minimum total system memory: 512 MB
Non-ECC DIMMs
Serial Presence Detect
DDR2 800 or DDR2 667 MHz SDRAM DIMMs
DDR2 667 SIMMs with SPD timings of only 5-5-5 (tCL-tRCD-tRP)
DDR2 800 SIMMs with SPD timings of only 5-5-5 or 6-6-6 (tCL-tRCD-tRP)
Intel DH55PJ - http://www.intel.com/support/mothe [...] 031469.htm
Two independent memory channels with interleaved mode support
Support for non-ECC, unbuffered, single-sided or double-sided DIMMs with x8 organization
8 GB maximum total system memory (with 2 Gb memory technology).
Minimum total system memory: 1 GB using 1 Gb x8 module
DDR3 1333 MHz and DDR3 1066 MHz SDRAM DIMMs
Please provide links to the RAM used in both systems so I can check if they are compatible.
first computer:
intel dg31pr
second computer:
DH55pj
The 400W PSU on the second system is small if you have graphics card added or OC.
Question - what happens if you use the 'old' RAM the worked before??
Message edited by jaquith on 02-02-2011 at 09:54:22 PM
Reply to jaquith
- 0 +
i put everything back as it was before .... when it worked
but now i dont have any idea what to do
btw - the second pc does not have an added gpu it uses the built in one
and - thanks everyone i appreciate the help
Reply to wickreD
- 0 +
so no one has an idea?
Reply to wickreD
- 0 +
Yes, get new/exchanged compatible RAM, and don't mix-match with your current RAM.
DG31PR - http://www.crucial.com/store/listp [...] del=DG31PR
DH55PJ - http://www.crucial.com/store/listp [...] del=DH55PJ
Reply to jaquith
- 0 +
thanks anyone , i belive that this ends here , thanks alot for helping me
אשכים אשכים אשכים אשכים
i guess ill just take it to the local computer shop...
thanks :D
Reply to wickreD
There are 2071 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 4 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
