Hello all,
I have cloned my works network setup at home to use as a test bed before doing anything at the office. They have a Bell Wired/Wireless modem with a built in firewall and DHCP server, then from there it goes to the server running SBS 2003 and ISA 2004. The only difference between the companies setup and mine is I am not with bell so I bought a Linksys BEFSX41 wired firewall router.
When i try to remote desktop to a workstation at home I get the following, and this does not happen at my company.
0x0 ERROR_SUCCESS External Local Host - SERVERONE Firewall
then
0x80074e21 FWX_E_ABORTIVE_SHUTDOWN External Local Host - SERVERONE Firewall
Port forwarding on the linksys router is setup, ISA non-web publishing policy and access rule are setup.
Thing is if i take the linksys router out of the equation everything works fine. I have tried playing with the very few configurable options on the router but nothing helps.
I have been researching this problem online for over a week now and have tried a few suggested fixes, none of which worked.
Anyone have any suggestions?
then
