Ok I am building a new PC for myself. It will be my first complete build.
I will be using the Gigabyte 890 ud3h
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435&cm_re=gigabyte_890-_-13-128-435-_-Product
and will be using either the AMD Phenom II 3.4ghz quad core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727&cm_re=amd_phenom_II-_-19-103-727-_-Product
or the new 3.2ghz 6 core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103849&cm_re=amd_phenom_II-_-19-103-849-_-Product
I would really appreciate advice on what combination of components to get.
I would prefer to use supertalent ram since its made in the USA. But if there is other ram made in America I would be open to it. I would like to fill all my dimm slots with 8 gigs of ram. What is THE FASTEST, BEST RAM that I can put in this thing? Heat might be an issue so I need it to run as cool as possible. Prince is not an object when it comes to this things ram.
I am using a rather old full tower case and am unsure as to it's airflow efficiency, so heat may very well be a serious issue that I need to deal with. It dose have 4 80mm stock fans though.
SO
A. Which processor runs cooler? The 4 or the six core?
B. I need to seriously cool this thing. What is the best and (and preferably quite) way to do this under $100? What fan/heatsink should I use? I'm concerned because the dimm slots are rather close to the CPU and it needs to fit and not overheat the ram.
I want this thing to be as fast as possible. Thanks ahead of time.
PS This is my first time building anything with new components. I'm used to working with old stuff so if Anything I'm doing here sounds really stupid please correct me.
SO
