Case (CM 690 II) $89.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216
Mobo (ASUS M4A79XTD EVO) $118.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
GPU (ASUS EAH5850) $319.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121375
CPU (Phenom II X4 965BE) $181.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
RAM (4GB DDR3 1600) $109.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
HDD (WD 1TB 7200RPM) $99.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
PSU (CORSAIR 750W) $109.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CD/DVD (Sony) $21.99: http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
TOTAL (shipped): $1,073.54
This is what i have so far... if there are better options for around the same price (or cheaper) please let me know
I pretty much just do lots of gaming. I try to play everything new that comes out and like to play on the highest settings if possible. My monitor resolution is 1920x1080 btw. I don't plan on overclocking anything... but if you think it's possible (since i'm using stock air cooling) and a good idea with this build then let me know. Also i'm hoping to use this system for a while.
