robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #1 Hi. I just built a new PC and Im getting a lot of BSOD. Windows says i have memory problems, is there any way i can fix it?. Specs: Intel i7 930 Evga x58 Sli Le Galaxy Nvidia GTX470 OCZ Gold 1600 mhz 3x2 GB Thanks for any help
Solution J J jbakerlent May 14, 2010 Also, after running memtest+ try running only one stick at a time and seeing if you still experience problems.
J jbakerlent Distinguished Jul 11, 2009 2,289 0 20,160 May 14, 2010 #2 Try running it through Memtest86+ see if you get at least one full pass with no errors. Upvote 0 Downvote
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #3 I tried the memory tester that comes with windows and it failed, does this count? Upvote 0 Downvote
J jbakerlent Distinguished Jul 11, 2009 2,289 0 20,160 May 14, 2010 #4 I'm not sure what memory tester that is... Try downloading memtest from here http://www.memtest.org/#downiso Do you have a case speaker? If so, what beeps are you getting when you start your computer? Upvote 0 Downvote
J jbakerlent Distinguished Jul 11, 2009 2,289 0 20,160 May 14, 2010 #5 I assume you haven't changed any of the settings or voltages? Upvote 0 Downvote
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #6 Ill try that tester, and I only get one short beep when it turns on. Thanks! Upvote 0 Downvote
J jbakerlent Distinguished Jul 11, 2009 2,289 0 20,160 May 14, 2010 Solution #7 Also, after running memtest+ try running only one stick at a time and seeing if you still experience problems. Upvote 0 Downvote Solution
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #8 Got it, ill post when I finish. Upvote 0 Downvote
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #9 Ok here is the test result for all the sticks. [/URL] Uploaded with ImageShack.us[/img] Upvote 0 Downvote
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #10 Ok, now I'm testing the stick one by one. Upvote 0 Downvote
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #11 Only one stick didnt pass the test. Now I know whats going on, but is there any way to fix it? Upvote 0 Downvote
J jbakerlent Distinguished Jul 11, 2009 2,289 0 20,160 May 14, 2010 #12 You're going to need to replace that stick. If you can return them to where you bought them (assuming they are under warranty still). Upvote 0 Downvote
robjamar Distinguished Jan 4, 2010 94 0 18,630 May 14, 2010 #13 Best answer selected by robjamar. Upvote 0 Downvote
