APPROXIMATE PURCHASE DATE: Couple of Days
BUDGET: This is close to my maximum budget ($2100ish.) The monitor does make up 1/4 of the cost, so I might consider less expensive 1920x1200 options.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Software Development (8 hours a day) with the ability to game on the highest settings. System to last several years with minimal upgrades. (i.e. Ability to add a 2nd Geforce GTX 470 at some point)
PARTS NOT REQUIRED: keyboard, mouse
PREFERRED WEBSITE(S) FOR PARTS: newegg, amazon
PARTS PREFERENCES: Intel, nVidia
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Eventually
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS: Worried about heat, noise and the future like everyone else. Also want to make sure the graphics card will fit easily in the case with enough clearance and airflow (especially after adding a 2nd.) Where could I possibly skimp to save some $$$ without losing out on performance.
Thanks in Advance!
MOBO ($240): ASUS P6X58D-E LGA 1366 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
CPU ($289): Intel Core i7-930 Bloomfield - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
HSF ($30): COOLER MASTER Hyper 212 Plus - Sold Out on Newegg - http://www.amazon.com/Cooler-Master-Hyper-212-Plus/dp/B0037JT78C/ref=sr_1_3?ie=UTF8&s=electronics&qid=1273820424&sr=8-3
GPU ($350): EVGA GeForce GTX 470 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550
HDD ($215): Intel X25-M 80GB SSD - http://www.newegg.com/Product/Product.aspx?Item=N82E16820167023
HDD 2 - Using existing 500GB drive
RAM ($180): G.SKILL Ripjaws Series 6GB (3x2GB) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304
CASE ($100): COOLER MASTER HAF 922 - Sold Out on Newegg http://www.amazon.com/gp/product/B0026FCI2U/ref=ord_cart_shr?ie=UTF8&m=ATVPDKIKX0DER
DVD ($22): LITE-ON 24X DVD Writer - http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
PSU ($120): Antec TruePower 750W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371022
MONITOR ($510): Dell UltraSharp U2410 24" LCD - http://www.amazon.com/Dell-UltraSharp-U2410-widescreen-DisplayPort/dp/B00302DNZ4/ref=sr_1_1?ie=UTF8&s=electronics&qid=1273604533&sr=8-1
OVERCLOCKING: Maybe
Thanks in Advance!
