First build need advice. Buying parts tomorrow!
APPROXIMATE PURCHASE DATE: tomorrow BUDGET RANGE: 700 FIRM
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: little gaming. Mostly WoW. Movies.
PARTS NOT REQUIRED: have monitor/keyboard
PREFERRED WEBSITE(S) FOR PARTS: Newegg
PARTS PREFERENCES: amd
OVERCLOCKING: maybe SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 17 inch old lcd
Just wanna make sure everythings compatible before I purchase. Suggestions are welcome but I'm not spending no more.
Case- Antec 300
cpu- AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128431
gpu- nvidia 9800GTX+ 512mb 256bit
ram- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
psu- 600w http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
hard drive- SAMSUNG spinponit s3 500gb 7200rpm
4 answers Last reply
More about first build advice buying parts tomorrow
  1. Looks pretty good. Here's a few changes I might make though.
    First, make sure you are getting this revision of the X4 955
    AMD Phenom II X4 955 -$160-
    Then consider this RAM with tighter timings
    G.Skill Ripjaws -$116-
    Consider a 5750 instead of the 9800
    XFX Radeon HD 5750 -$130-
    For overclocking, you may want to add in this HSF
    Cooler Master Hyper 212 Plus -$27-
  2. Honestly i dun think u even need a 955BE seeing u have little to nil CPU intensive tasks outside games so why not
    AthlonII X3 440
    870/880G mobo with native SATA 6GB/s and USB 3.0
    and ya that HD 5750 is a good call but for green camp you'd be looking at GTS 250 not 9800GTX+ : a refresh/rebrand but a wee bit more frames and considerably less power consuming
  3. ^ Agree.
  4. Although WOW does use the CPU to render characters on the screen
New Build Systems Product
