Hey there. I am stumped at this issue. I have an XFX NFORCE 680i LT SLI mobo with a Q6600 in it. Not overclocked.
I have 2 sticks of 6400 ddr2 ram in there. Its OCZ Vista upgrade ram (pc2 6400 5-5-6), each is 2gigs, for a total of 4gigs of ram.
For some reason one of the sticks is running slow. The bios has not been messed with, never change the voltage. I even have a spare stick of the exact same ram, I swapped it out and its still running slow.
Here is the Sandra scan readout.
Logical/Chipset Memory Banks
Bank 0 : 2GB DIMM SDRAM
Bank 1 : 2GB DIMM SDRAM
Maximum Installable Memory : 2GB
Supported Memory Types : ECC DIMM SDRAM DDR2
Memory Bus Speed : 1x 667MHz (667MHz)
Maximum Memory Speed : 1x 667MHz (667MHz)
Width : 128-bit
Power Save Mode : No
Fixed Hole Present : No
Maximum Memory Bus Bandwidth : 10.42GB/s
Here you can see the first module is running at DDR2-666. I cannot figure this out. Is the mobo just crap and is dying?
Memory Module
Manufacturer : OCZ
Model : OCZ2VU8002G
Type : 2GB DIMM DDR2
Technology : 16x(128Mx8)
Speed : PC2-5300U DDR2-666
Standard Timings : 5-5-5-15 3-20-5-3
Version : 1.02
Memory DC Line : 1.80V
Timing @ 333MHz : 5-5-5-15 3-20-5-3
Timing @ 267MHz : 4-4-4-12 2-16-4-2
Timing @ 200MHz : 3-3-3-9 2-12-3-2
Memory Module
Manufacturer : OCZ
Model : OCZ2VU8002G
Speed : PC2-6400U DDR2-800
Standard Timings : 5-6-6-18 3-24-6-3
Version : 1.00
Timing @ 400MHz : 5-6-6-18 3-24-6-3
Timing @ 333MHz : 4-5-5-15 3-20-5-3
Timing @ 267MHz : 3-4-4-12 2-16-4-2
I was going to get new ram till i tried my spare module. Now, I have no idea. new mobo? Thanks for any info.
Width : 128-bit
Memory Module
Manufacturer : OCZ
Model : OCZ2VU8002G
Version : 1.02
Memory Module
Manufacturer : OCZ
Model : OCZ2VU8002G
Version : 1.00
