Installation Problems
I'm trying to install Windows XP, and it seems like it goes through the installation problem alright, but then when it reboots after the blue installation/file copy screen
This one.
it just gets stuck on the "Press any button to boot from CD," screen.
To try and fix it, I went through the XP Install again and afterwards changed my BIOS to just boot directly from the HDD, but to no avail, I just get left with a black screen with a flashing underscore.
Anyone know the problem?
1 answer Last reply
More about installation problems
  1. your settings will be cd/dvdrom 1st, then only hard disk correct?
Boot Windows XP
