Sign-in / Sign-up
Gpu and mobo problem!!
  • Asus
  • GPUs
  • Compatibility
  • Components
  • Motherboards
January 31, 2011 8:39:52 PM
Hi, im about to build my first system, i doubled check all my components to see if they are all compatible, but i bumped into a problem, my gpu card is a 2.1 and my board says that the pci-e slot is a 2.0 slot, will it still fuction properly.
Thanks
More about : gpu mobo problem
a c 717 V Motherboard
a c 207 Ĉ ASUS
January 31, 2011 8:44:50 PM
Welcome to Tom's Forums! :)
Yes it will work, the GPU is backwards compatible. The real question is what MOBO, CPU, and GPU?? This is to check if your CPU/MOBO won't bottleneck the GPU.
m
l
January 31, 2011 9:04:12 PM
Mobo: ASUS M4A89TD PRO
GPU: XFX HD-585X-ZAFC Radeon HD 5850 1GB CFX
CPU: AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz AM3
m
l
a c 207 Ĉ ASUS
January 31, 2011 9:28:30 PM
You're good! :)
m
l
a b V Motherboard
February 1, 2011 4:56:40 PM
^+1
m
l
