Solved
Formatted my Secondary Hard Drive and now there is a problem
My secondary hard drive shows up with two hard drives on my computer, and i formatted the first one successfully (Acer (G:)). But when i did the same thing with the second one (Local Disk (H:)), it said "Windows was unable to complete format".
Now it isn't recognised as a hard drive anymore, therefore i can't use it.
This is how i formatted them.
Right Clight > Format > Capacity 330GB (Both hard drives are 330GB), File System NTFS (default), Allocation unit size Default Allocation Size, Quick Format > Start.
So yeah, that worked for the first one, but not the second one. Local Disk (H:).
I included a picture if it would make it more clear.
http://imgbucket.info/i-wbjJc/hard drive issue.jpg
3 answers Last reply Best Answer
More about formatted secondary hard drive problem
  1. Best answer
    go to DIsk Management and you can delete and create new partitions there as well as format them.
  2. Thanks, the problem has been fixed.
    *Admins please close this discussion*
  3. Best answer selected by Alzza.
Hard Drives Format Storage
