Hello, I'm a new builder and I have two questions.
First off, will the RAM and motherboard below be compatible? Because the mobo doesn't say anything about 1600, only 1333 and 2000 whatever?
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131668&cm_re=Amd_am3_880g-_-13-131-668-_-Product
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=Ripjaws_1600_4gb-_-20-231-303-_-Product
Second question, should I get that RAM or it's 8GB (2x4GB) cas latency 9 counterpart?
Thanks a lot in advance!! :]
