Solved
Alright got my parts, anyhting I should be aware of?
Last response: in Systems
newegg finally shipped all my parts and I'm preping to build my system. Any tips or cautions before I start?
What I have:
  1. IN WIN Ironclad Black SECC Steel ATX Full Tower Computer Case
  2.
  3. SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
  4.
  5. Sony Optical Black 24X DVD
  6.
  7. ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen 16:9 Full HD 1080P LCD Monitor 300 cd/m2 1000:1 (ASCR 12000 : 1) Built in Speakers
  8.
  9. X4 955 + 5850 ASUS OC'ed (they have the non oc one 20 dollars cheaper but the combo is -30 so I save 10 bucks
  10.
  11. Antec TruePower New TP-750 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE Certified Active PFC "compatible with Core i7/Core i5" Power Supply
  12.
  13. G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL8D-4GBHK
  14.
  15. ASUS M4A Pro + Coolmaster 212
  16.
  17. Fatality Sound Card
I've read the step-by-step guide, but I'm wondering if there are any additional issues I should watch out for while building as I don't want to screw up on my first try >.<?
I have a antistatic strap so i should be safe there.
Just be gentle with your parts, thats really all you can do.
You should always double check whether your parts are 100% compatible, or work together. What I do is for example, with my mobo, I went to newegg... and looked at all of the reviews. I crtl + f (find) the exact same parts ex. the AMD Phenom x2 555 3.2Ghz, I checked to see if it has any problems with windows 7 (the original board I wanted to get had clock issues).
It looks like your parts should be good though, especially if some are in a bundle.
Good luck on your build! again, be careful if its your first time.
Related ressources
I don't get anything onscreen even though I see the power on. no HDMI output. So I'm wondering if I may have connected something wrong
edit: Theres a red light next to the memok button, I'm guessing its a RAM issue?
Yes, tried both black/blue.
I get a long beep and two short beeps and have no clue whats wrong with my video card. Remounted it 3 times and no luck. Tried using onboard and it still gives me beeps
booting with hdmi does work right?
Homebuilt system Master
Have you reviewed & complete all the items in the checklist I posted earlier? Your beep codes should point to the error and use the checklist to troubleshoot.
Do you have both PCIe power connectors plugged in??
Is it in the slot closest to the CPU??
Have you tried booting through VGA, DVI or HDMI to see if one works and the other doesn't?
Have you done the same with the on-board video??
Have you tried another GPU to see if it'll boot?
Tried them all, cept vga as I can't find the cable for that and the graphics as my 5850 is the only one at hand. I did try integrated.
I'll go back to the mobo manual and see what else I can do. :(
I'll call it a day and figure this out tomorrow. From what I've googled I assume I got a bad mobo
just did a bit more googling and found that it could be related to my RAM. i can't seem to find where in the manual to find out what 1 long beep and 2 short ones mean so I guess I'll call ASUS
Best solution
I say screw it... Go to Microcenter and buy yourself an i7 930, ADUS P6T and some triple-channel memory and call it a day with an updated build... :)
Ask the community
