Basically my computer turned off on me last night and when i tried to turn it back on it would begin to start up for about a second then do nothing for around 5 seconds and repeat the process. So from looking on this sight i figured it might be the power supply, but I had a working power supply from another computer and tried that and it fixed nothing.
So I was just unplugging and plugging in trying to figure out the problem and I found that when i unplug this plug on the top of the motherboard the computer will start up. As soon as i plug it back in the computer it turns off and does the same thing.
I dont know my computer terms very well so sadly i dont know what this plug is called so I took a picture of it (its the white one) and any help on what i should do or what the problem might be would be appreciated.
I tried to code the image but it was just giving me an error so here is the link
http://s351.photobucket.com/albums/q479/shadowwound50/?action=view¤t=IMG-20110203-00010.jpg
If already posted somewhere, I am sorry I looked around for quite a long time finding nothing, thanks.
gigabyte ga-p35-ds3l motherboard
