Hello, I decided to upgrade my AMD FX-60 to and AMD Phenom II x4 965.
I need help on what motherboard to use please. I am confused with all that motherboard variety out there.
I like Asus and probably Gigabyte, from what I can read here.
I plan to do video editing (HD gopro camera video, with AVS video editor software) and some gaming.
My budget for the motherboard is around $150 if possible.
Memory is also a confusing part for me, I heard corsair XMS is good. I will start with 4GB.
I also want to reuse ( I guess I need to check the specs of my old parts for compatibility).
-Old ATX case, with 850W power supply.
-eVGA Nvidia 880 GTX PCI ???
-Acer monitor 19??
Thank you very much for any tips!
-Acer monitor 19??
