Hey I'm building a new system before i head back to college, so my budget is pretty slim but I'm able to squeeze out a max of $1,200. Can i get some advice on this build i am using it for homework, and Crysis / Eve-Online. I have absolutely no idea on a good MOBO for this build so any advice there will be awesome.
2x SAPPHIRE Radeon HD 5830 1GB 256-bit GDDR5 PCI Express 2.1 x16 $489.98
http://www.newegg.com/Product/Product.aspx?item=N82E16814102878
1 CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC
Compatible with Core i7 Power Supply $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
1 ASUS Black SATA DVD-ROM Drive Model DVD-E818A6T/BLK/B/G $16.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135202
1 Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5 $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
1 G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
1 Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 $194.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
1 Thermaltake Armor+MX VH8000BWS Black Aluminum / Steel ATX Mid Tower Computer Case $128.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133062
