Last Friday I assembled my first gaming PC (a budget build) and besides a few minor mid-build crisis, everything turned out fantastic. First boot was a success, Windows installed fine, and for the past few days I've had nary a problem installing drivers, software and playing games.
Here are the parts I used:
ASRock 880G EXTREME3 AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157191
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM $19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Rosewill Green Series RG630-S12 630W Continuous @40°C,80 PLUS Certified, Single 12V Rail, Active PFC $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182200
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
SAPPHIRE 100283-2L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready
-AND-
AMD Athlon II X3 440 Rana 3.0GHz Socket AM3 95W Triple-Core Desktop Processor Model
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.388234
Antec Three Hundred
http://www.bestbuy.com/site/Antec+-+Three+Hundred+Computer+Case/9254656.p?id=1218069452235&skuId=9254656&st=three%20hundred&cp=1&lp=1
TOTAL = $760
I was originally going to use an old case, but as I was testing to make sure all the risers were in the right place for the motherboard, I discovered I was short by about three and had now idea where to get some new ones. I ran out to Bestbuy after doing some quick review checks on that Antec Case and finished building (after removing the PSU, DVD drive and hard drive).
After that, everything worked out great (though the motherboards Powerswitch, HDLED, etc. plugs could have been better labeled). I used the "How to build a PC" thread above to guide me through the process.
Here's a picture of the computer. I tried my best to have clean cable management (and now understand the benefit of a modular power supply) and kept any cords from resting on the GPU or motherboard.
The CPU runs nice and cool, around 31 C browsing the web and usually no more than 40 C when playing games. Speaking of which, I have yet to do professional benchmarking, but I do know that I can play the Starcraft II beta and Left 4 Dead 2 at max settings with smooth frame-rates on my 1080p monitor, so I'm very happy with the performance. Down the line, I should have plenty of room to overclock my processor and Crossfire with another 5770.
I just wanted to thank the community for all your help in recommending parts and putting together some super detailed "how-to's".
-AND-
Antec Three Hundred
TOTAL = $760
