First Build - Need HElp
Case: COOLER MASTER ELITE 335 RC-335-KKN1-GP Black SECC Steel ATX Mid Tower Computer Case
Power Supply: OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
Motherboard: ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard
CPU: AMD Phenom II X2 555 Black Edition Callisto 3.2GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Desktop Processor - C3 Revision
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
Hard Drive: Western Digital Caviar Black WD7501AALS 750GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
GPU: SAPPHIRE Vapor-X 100283VXL Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
DVD/CD Drive: LITE-ON Black 24X DVD+R 8X DVD+RW 8X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - Bulk - OEM
This is my first build and I have questions about my build.
Are all the components compatible with each other?
Will they work okay together?
Can this run Windows 7 Ultimate 64-bit?
I eventually plan to crossfire two 5770s and maybe upgrading to a Phenom II X4 or X6.
1 answer Last reply
More about first build help
  1. Welcome to the forum. It all looks compatible, but I would recommend some changes. First though, it would be best if you filled out the Build Advice form in my signature for the best help.
New Build Systems
