So i bought a new motherboard from newegg a week ago and it is the A770E3 motherboard. The problem that im having is that i wanted to test the motherboard so i put the cpu on it (amd athlon II) and powered the motherboard without RAM and without video card but there is NO beep or anything but the CPU fan works and also if i connect any usb devices in the motherboard's usb ports they wont work... does this means that the motherboard is bad or that i need to put ram and then test it?? please help im new to thisss
thanks..
thanks..
