Micro sd card problems
Hello,
i was using my sd card for my blackberry, when all of a sudden it stop working, blackberry was telling me it has fatel errors on it and can not be access, so when i tried to use it on my pc, it told me it needs to be formated in order to use it, is there some sort of way for me to retrive photos and videos from the card before i formated to star using it again? Cause i really need the files thats on the card, don't want to lose them...
2 answers Last reply
More about micro card problems
  1. TestDisk, Data Recovery
    TestDisk is powerful free data recovery software! It was primarily designed to help recover lost partitions and/or make non-booting disks bootable again when these symptoms are caused by faulty software, certain types of viruses or human error (such as accidentally deleting a Partition Table). Partition table recovery using TestDisk is really easy.
    TestDisk Step By Step to recover lost partitions and repair damaged FAT/NTFS boot sector
    Recover deleted files from NTFS partition
    NOTE If seeked lost file are still missing, give PhotoRec a try. PhotoRec is a signature based file recovery utility and may be able to recover your data where other methods failed.
    PhotoRec is file data recovery software designed to recover lost files including video, documents and archives from hard disks, CD-ROMs, and lost pictures (thus the Photo Recovery name) from digital camera memory. PhotoRec ignores the file system and goes after the underlying data, so it will still work even if your media's file system has been severely damaged or reformatted.
  2. melvin117 said:
    Hello,
    Try to link your sd card to another pc, if it still reports that sd card needs to be formatted, then it is very likely that your sd card has got virus or been damaged. Try free data recovery that can help you restore your sd card photos video files.
    http://freeware-recovery.blogspot.com/2012/07/free-delete-format-recovery.html
    It's a free software and I once used it to recover my files. You just need to download and install it. The operation is easy, follow the instructions and your files will be saved.
    But don't save your files in that sd card again, store them in another one or your pc, and remember: sd card is easy to get corrupted, so it's better to store your important files in pc. Good luck!
Flash Media Micro Sd SD Card BlackBerry Storage
