During the Black Friday, I got a HIS 5670 1GB graphic card and A-Data 2x2G Ram
Graphic card detail:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161334
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211466
After I putting the parts in, it starts to have blue screen problem once a while.
Note: it always happen when I first turn it on, if the first 5 min don't have the blue screen it will work normally through out the day. The chance it happen is about 50%
First I was thinking connection problem, so I reconnect all wires; doesn't help at all.
Now I take out one of the two rams it seem working normal again (at least for now)
SO I wonder is it something wrong with the Ram or other problem.
By the way, my PC run 32 bit window Pro
Thank you !
hope someone can help.
If any more info is needed I will more than welcome to provide that is needed.
Ram
Thank you !
