Help a case mod noob!
Last response: in Components
Take a look at the links in my sig, I like cutting holes in cases hehe
Another option for you is mark the screw holes using the fan placed (on the inside) on the panel, mark the circle as Yiplong said, then clamp the panel down and drill lots of 3-5mm holes inside the circumference, make sure its all supported underneath AND something on top as well, stops the panel deforming when you attack it :p
Moto
Related ressources
Ask the community
