Two audio output devices
  • Sound Cards
  • Audio
  • Devices
  • Components
Last response: in Components
July 23, 2010 6:41:09 PM
I did a custom build and put a Creative card in it. I have Klipsch Pro Media speakers hooked to it and it sounds great. My monitor is a 32" Samsung HDTV. I want sound to come out of the tv also. How can I achieve this?
I have another sound card and onboard audio and the tv has an audio in jack.
More about : audio output devices
July 24, 2010 11:58:20 PM
Hi,
probably you can plug jack-to-jack from one Creative's line-output to monitor's input, you will get sound but no HD sound;
for HD sound you got to check if your sound card (probably onboard soundcard if mobo is pretty new) has HD capabilities and if your graphic card can be linked (internal cable) to it. Check both soundcard (mobo) and graphic card manuals. This way you'll get HD sound from HDMI monitor connection.
Hope it helps
m
l
