Ok, this has been bugging me for a while. What exactly does the MHz of ram that a CPU supports mean? I mean, obviously you can overclock the ram.
Is it simpler than I think? Is it that the CPU will run any faster ram at it's own spec speed unless overclocked? ie, the Athlon IIx4 would run DDR3 1333 at 1066MHz?
Another question, is if my assumption is correct, then why are high end CPUs currently limited to 1333MHz ram? Is there some kind of technological limitation that needed to be worked out that I am missing here?
Thanks in advance
Thanks in advance
