Graphics card help!!!
i need help getting a decent graphics card that will run the games out right now...i only have $200 to spend...btw i have an i7-860/4gb ram setup....plz help thanks.
4 answers Last reply
More about graphics card help
  1. what is your power supply?
    what is your monitor's native resolution?
  2. +1
    the 5770 is the best card in your price range.
    depending on monitor resolution it should be capable of maxing out most games at very good framerates.
  3. Assuming your PSU is at least a good 400-500 watter. I'd get this if you intend to overclock. There really isn't anything at $200 but just below it is the 5770, which is currently the mainstream card to get. This model is great if you intend to overclock.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127490&cm_re=5770-_-14-127-490-_-Product
Graphics Cards Intel i7 Games Graphics Product
