Hey I just built this rig. It performs flawlessly without a hitch, but it sounds like a flying saucer when playing Crysis.
Phenom x4 965 3.4ghz BE
Gigabyte ATI Radeon 5870 1GB
Gigabyte GA-890GPA-UD3H AM3
4 GB Corsair 1333mhz DDR3 Dual Channel
Corsair 750tx
Coolermaster 690 II
Asus DVD Drive
D-Link Wireless-N PCI
CPU Idle temp : 35c 35c 38c 37c
CPU Load : 45-55c Crysis Are these temps ideal for cpu longevity?
Gpu temp : Unknown (Help?)
Would anyone recommend installing more fans into the CM 690II case? Now it has : Front - 140mm, Rear - 140mm
Also, will adding another 4GB of ram improve my gaming performance? (Particularly when enabling AA in Crysis)
When playing Crysis there is a 2" black border on my 42" screen all around at any resolution. (1920x1080 native) I am running ATI Catalyst 10.3 drivers. I already changed settings to remove it from desktop.(scaling) Now I just need to remove it from Crysis.
Thanks a lot, these are kind of hard questions I know.
Corsair 750tx
Coolermaster 690 II
Asus DVD Drive
