Will these parts fit?
Hey i've made my little shopping list of components i had a £400 spending limit and i've got it to £396.37 which is perfect, please could someone look over the componenets i've picked and tell me if not only will the motherboard fit and if all the components will fit in the motherboard
Graphics Card
http://www.ebuyer.com/product/201198
Hard Drive
http://www.ebuyer.com/product/158860
Motherboard
http://www.ebuyer.com/product/181968
Processor
http://www.ebuyer.com/product/166518
Optical Drive
http://www.ebuyer.com/product/176026
Power Supply
http://www.ebuyer.com/product/102994
Case
http://www.ebuyer.com/product/143854
RAM
http://www.ebuyer.com/product/147903
Sorry to be annoying im just no good at knowing wheather there going to fit and i dont want to waste money as i havent got alot :(
Dimentions of case: 18" (H) x 18.3" (D) x 8.1" (W)
Dimentions of motherboard: 9.6" x 8.2"
Thank you for helping :'} :love: :D
22 answers Last reply
More about will parts
  1. Yes, all the parts are compatible with each other.
    Good luck!
  2. Thank you :) and will the motherboard fit in the case nicely? :)
  3. ^ Well assuming you are building a gaming PC, I have some suggestions...but before that, could you tell what is the resolution of your monitor ??
  4. o.O oh god its a terrible monitor tbh only like 19" i dont know the rezolution :{ sorry
  5. ^ hmm even a 19" has pretty decent resolution...If it is a wide screen, it can have upto 1680X1050 or 1440X900...
    And change the mobo to this...Just few bucks more, but opens up the option of unlocking the cores in the Phenom II as it has ACC in the BIOS...
    http://www.ebuyer.com/product/185913
    Just search Phenom II X2 unlocking in google...
    And the quality of the PSU is very questionable...I would rather spend less on the case and get a better quality PSU...
    HDD - get the Samsung F3 500GB instead...It is faster and more reliable...
    http://www.ebuyer.com/product/146252
  6. so if i had
    Graphics Card
    Hard Drive
    Motherboard
    Processor
    Optical Drive
    Power Supply
    Case
    RAM
    that would be better?
    the reason i chose that case is because i was worried the otherones wouldnt fit the motherboard.
  7. ^ Just get a case which says ATX compatible and has atleast 1 FAN...
    Get this case...IMO it looks to be good one and at a very good price...
    http://www.ebuyer.com/product/172779
    Or these also will do
    http://www.ebuyer.com/product/160805
    http://www.ebuyer.com/product/191865
    And with the money saved, get this PSU
    Far better quality...
    http://www.ebuyer.com/product/135159
    And certainly change the graphics card to this one...Though about 5 bucks more, its worth it...
    Sapphire HD 5770 512MB - Though it only has 512MB, IMO it would suffice for a 19" and also the 5770 chip would compensate for it and actually you would get better frames than the 5750...
    http://www.ebuyer.com/product/199404
  8. ok so i've chosen to go with the top case and the psu :) thank you for those, but with the graphics card, i plan to upgrade my monitor so should i get the 5770 or 5750?
  9. Go for the 5770. There is a surprising amount of difference between these cards and you get more bang for your buck.
  10. ^Yes...HD 5770 is a better choice...
    If you will be getting say a 1080p resolution monitor, then investing a little more in the HD 5770 1GB would make sense as the 1GB frame buffer would do good for that resoluiton...
    and also a note...if you have not planned for core unlocking or anything, then the Athlon II X3 would be a very good choice IMO...
    The extra core does help...
    http://www.ebuyer.com/product/176043
    http://www.ebuyer.com/product/191955
  11. So i should get a different processor? i thought the AMD Phenom II X2 550 Black Edition 3.1GHz 6MB L3 Cache was a great choice :/ please help, you've been so much help so far :') thanks
  12. ^ Those are good no doubt...they were a famous choice for another reason - Core unlock...AMD locks the unstable cores of the Quad-core chips, and sell them as dual cores...So there is a possibility that you can unlock these cores by using the ACC option in the BIOS...But there is no 100% guarantee that those unlocked cores would work fine...
    Later AMD launched the Tri-Cores, which offered better performance in multi-threaded apps and the absence of the L3 cache was not that significant for these CPUs...So the new Athlon II X3s became the best option for this budget range...
    Check out the suggestions provided by the TOM's website...
    http://www.tomshardware.com/reviews/gaming-cpu-core-i5-phenom-ii,2620-2.html
  13. So all in all without overclocking or anything just the pure prosessor would the
    x3 440
    or the
    Phenom X2 550
    what would be better to get? thank you
  14. ^ If you want to take chances, then get the X2 550 - Can be changed to a Phenom Quad...But anyways its a fast Dual core too...
    But if you want to play safe, then the X3 440 is a good option as you get a stable 3 core CPU...
  15. thank you :) you've been a huge help im going to be ordering these parts tonite :D
  16. Good luck!
    May I ask what you basing this off? As in why do you say that the Be Quiet PSU is a bad one? I have read a positive review of it (stable voltages, high efficiency and quietness), admittedly the review I read wasn't that indepth, but it was positive nevertheless and it's rated for almost all the 530 watts on it's 12V rail. Which is more than the OCZ StealthXStream.
  18. ^ Sorry I dont see any Be Quiet PSUs being linked here...
  19. The one that was originally in the OP, but got edited out because of what you said: http://www.ebuyer.com/product/190751
  20. ^ Well he had listed a extra value PSU which was cheaper...and not the Be Quiet one...You could see in my initial posts...Notice the post that you had quoted ? I had said with the money saved, get a better PSU...Well there is negligible difference between that OCZ and the Be Quiet PSU...So if the OP had linked that PSU, I dont think I would have brought the price factor into the picture...
    But I do remember seeing some post linking a Be Quiet PSU though...but not sure if it was in this thread though...
  21. ? Maybe I just assumed that he was linking to the Be Quiet PSU that I had recommended a few times to him. If so, I apologize.
  22. ^ Hey nothing wrong in asking the reasons...
    But am sure I recently saw a thread which had a Be Quiet PSU linked...So maybe the confusion...
New Build Components Motherboards Systems
