Solved
Replaced mobo-new one doesn't work either. HP support is no help
  • Motherboards
  • Hewlett Packard
  • Support
  • Thermal Compound
  • Power
February 8, 2011 8:14:18 PM
I bought an HP DC7100 SFF machine back in mid December, and it worked fine until the 26th. I ordered a new motherboard, because that is what I was told was the problem. After replacing, putting new thermal paste on cpu, and plugging everything in correctly. I pushed the power button, and for a breif second-everythhing looked great. Then the beeping kicked in. It's a steady beep every second, with no loop and the LED in the power button is flashing red. Please help if you can.
More about : replaced mobo work support
a c 1185 V Motherboard
a b α HP
February 8, 2011 8:31:25 PM
You buy used or new? All cables inserted correctly?
m
l
February 8, 2011 8:50:58 PM
server supply listed it as new, all cables are in right. since the fans shut off right away, do you think it to be a PSU problem?
m
l
Best solution
a c 111 V Motherboard
February 8, 2011 9:56:04 PM
The beeping is an indicator of failure. See if you can find anything here.
a b V Motherboard
February 9, 2011 12:33:30 PM
Anything could be the problem. Why didn't you return it for warranty??
m
l
February 9, 2011 7:21:25 PM
the ebay seller warranty went out 3 days before it died,and i may return the mobo if I have to, but if somebody has any kind of idea what's going on, please tell.
m
l
February 9, 2011 8:38:07 PM
no power loses conection or short cheack to make shore all cords are pluged in all the way and that the wire/s are going into the conecter fully one might be poked out when you push it in if you see the metal clip that clips to the pin on any conecter then that could be the issue u said it is a countinuos beep right
and with the red light error code look at this found here http://h18000.www1.hp.com/products/quickspecs/11948_div...
hit ctrl+f and type "red led" in the find bar and it was found there
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
so count the red led lights and find the code man
so the code for a power issue is 4 -1 sec red lights with 2 sec pause between each
m
l
February 15, 2011 11:00:17 PM
Best answer selected by levstad.
m
l
