Newbies first build, have most parts
APPROXIMATE PURCHASE DATE: Couple of weeks
BUDGET RANGE: ~700...
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming
PARTS NOT REQUIRED: LCD / Mouse / Keyboard / HDD(500g SATA) / Case / PSU (620W)
PREFERRED WEBSITE(S) FOR PARTS: Newegg, Tigerdirect, Frys
PARTS PREFERENCES: No brand loyalty.
OVERCLOCKING: Yes, but reasonable levels (new to OC'ing)
SLI OR CROSSFIRE: Would like to have future possibility open
MONITOR RESOLUTION: 1920x1080
After doing a bit of research:
CPU/MOBO
i5-750 Lynnfield @ 2.66 + EVGA P55 FTW - 250 (fry's deal - how is this deal???)
OR
X4 955/965/1055 + Any MoBo advice?
GFX Card
Radeon 5850 [Sapphire Edition] - 300
RAM
G.Skill Ripjaws 4GB (2x2GB) DDR3 1600 (7-7-7-24 @1.6V)
14 answers Last reply
More about newbies build parts
  1. COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ...
    Item #: N82E16835103065
    Return Policy: Standard Return Policy
    Protect Your Investment (expand for options)
    Service Net Replacement Extended Warranty
    The product will be replaced and shipped directly to you at no charge(more info)
    • 1 year: $7.99
    • 2 year: $12.99
    $39.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
    • AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX
    Item #: N82E16819103808
    Return Policy: CPU Replacement Only Return Policy
    o 1 year: $19.99
    o 2 year: $36.99
    • GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
    Item #: N82E16813128435
    o 1 year: $17.99
    o 2 year: $26.99
    -$15.00 Combo
    $299.98
    $284.98
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.391129
    • XFX HD-585X-ZNFV Radeon HD 5850 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
    Item #: N82E16814150491
    Return Policy: VGA Replacement Only Return Policy
    • G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
    Item #: N82E16820231303
    Return Policy: Memory Standard Return Policy
    -$10.00 Instant
    -$10.00 Combo
    $429.98
    $409.98
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.400342
    Subtotal: $734.95
  2. mobo? the gigabyte with the 890fx. dont know .search on newegg. sorry. i'l just edit this later on.
    That mobo will put him over his budget. I guess so does the HSF i posted but if he wants to OC he will need it.
    Sure there are different parts but ( we need to give them what they need for the budget they have ) or else why not just go X58/i7 930 with a few HD 5970s and raid a few 250 gig SSD.
  4. yeah ur ryt. maybe a 770t giga? and stuff in a 5670?
    If that's what fits his budget, but it dont
  6. $700 fits that. i think. with a rana cpu. and antec 300.
  7. Which PSU and case exactly?
    --Jin
  8. a corsair 550 or 500 wats.
    He has a case and psu so why tell him to get a higher priced mobo ? Why dont you read what he needs and post back with the parts and price.
  10. oh. i didnt read. . a higher price mobo because he's asking for any mobo advice.
    He needs a mobo, cpu, ram and a GPU for 700 bucks
  12. cpu:amd 955 3.2ghz
    mobo:GIGABYTE GA-890FXA-UD5 AM3 AMD 890FX
    gpu:ati hd 5770
    ram:gskill 4gb
    and u say a 890fx would not fit his budget. and with the 5770 card he will run games mostly at high. or even max. at his resolution.or maybe not :whistle:
    total $609.96.
    i dont know about the 5850.. sorry for not using combos.
    and also for no hsf.but get cm hyper 212. as suggested by niklas
  13. xurwin said:
    cpu:amd 955 3.2ghz
    gpu:ati hd 5770
    ram:gskill 4gb
    total $609.96.
    The HD 5850 will be a better match for his rez, IMO both mobo will do the job. if you add the HD 5850 at 140 more and the HSF at 30 its over his budget.
    I have a HD 5850 and play @ 1920x1080 and i even have to play at high and no AA on some games. vs very high and 4xAA so the HD 5770 would not be a grate card if you like to play with a lot of eye candy on.
    IMO the best card for a rez of 1920x1080 would be HD 5870 or a GTX 480
  14. yeah. your right. but the gtx480 right now is overpriced. and ati is just crushing nvdia. recomend to go for a 5850
New Build Systems Product
