Ok so I built a computer about a year ago and my CPU died recently (AMD Athlon dual core AM2+ I forget the name) so I bought another one to replace it (AMD 1055t 6 core AM3) but when I installed it and no matter where i plugged in my monitor nothing showed up
CPU Specs
Nvidia nForce 750a SLI
AMD 1055t 6 core 2.80 GHz AM3
2 1TB Seagate HDDs (Raid 0)
4GB Corisair DDR2 RAM
Nvidia GeForce 9800 GT OC (BFG)
Nvidia GeForce 9600 GT (XFX)
PCIe x1 Firewire card
PCI USB 2.0 Card
Ultra 1000w Modular PSU
Generic brand DVD-RW drive
Gateway 19in 1440x900 monitor
I have plugged in the monitor in both video cards and in the on-board graphics and nothing shows up. I heard that I needed to update my BIOS to use the new CPU but I would think I would at least be able to see the BIOS to know what to update with. If someone would be kind enough to help me troubleshoot the problem I would be greatful.
Thank you for reading and please help!
~~~~~~~~~~~~~~~~~~~~~[UPDATE]~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Ok so I got a processor that I know works on the mobo. I put it in and all went well. I updated the BIOS and it said "Process competed normally" or something similar. After this I reset my CMOS settings and restarted again. After this I turned off my computer, installed the new processor, and restarted. (Note: My keyboard normally flashes before the computer boots up) When I turned on the computer this time I heard everything. but my keyboard didn't flash and the monitor was still blank. So I put in the older processor again and this time the keyboard flashed (so I guess the CPU knows what plugged in) but the monitor stayed blank. So now I don't know if I did something wrong or if my new CPU is bad or if my mobo is bad.
Could someone please help again!! Thank you!
CPU Specs
PCI USB 2.0 Card
