Solved
Help choosing graphics card
I have a Dell Precision 530 (old tech) and i need to know what type of graphics card can it support ? It has an AGP slot and currently i got an NVDIA FX 1100 in it. Can my systeem support this card : VisionTek Radeon 3650 1 GB DDR2 AGP ?
9 answers Last reply Best Answer
More about help choosing graphics card
  1. If the card supports AGP 4x that the slot on your motherboard has it will work. http://pompone.cs.ucsb.edu/admin/530_Workstation/1specs.htm
  2. might not be worth it, if your CPU is ancient, it will not push the 3650 to it's potential...
  3. what CPU are you using?
  4. @jonpaul37: it's an Intel Xeon (2.4ghz)x2 processors.
    @rolli59: so will this work on my system ?
  5. Best answer
    According to the specs I linked to it will work and according to DELL http://support.dell.com/support/edocs/systems/ws530/en/sm/2excrd.htm#1148375
    It will accept AGP x4 cards.
  6. Best answer selected by techguy_v00.
  7. Thanks :) I'll just get this card then.
Graphics Cards Support Graphics Product
