Please comment/help on my first custom build
Hi,
I've upgraded many computers and know the basic about hardware. I would like to build my own computer, and have assembled the parts from newegg. Please look at my config (printed in a pdf file):
http://www.mediafire.com/?muz12tyzdyn
I'm not sure if I'm missing any vital components, such as extra case fans and perhaps a heatsink? Also, I'm not sure that the parts are completely compatible, but from the specs, they look fine. Should I also spend time and look at perhaps liquid cooling and/or artic thermal compounds, or do you think the temperature will be alright? Any further comments on which parts are bad, which I should reconsider, etc, are MUCH appreciated.
Thanks!
1 answer Last reply
More about please comment help custom build
  1. Also, is my 750W psu enough for future CF's?
Homebuilt Build Systems
