HI i wanted to know if this card would work (http://www.newegg.com/Product/Product.aspx?Item=N82E16814150466&cm_re=Radeon_HD_5670-_-14-150-466-_-Product)
on a antec 380 watt power supply
this is how strong it is
80 plus certified
DUAL 12v rails
+5v 20A
+3.3v 20A
+12v1 17A
+12v 2 17A
-12v 0.8A
+5vsb 2.5A
+3.3v and +5v max is 130watts
+12v1 +12v 2 max is 324 watts
sence it has dual 12v rails does it mean i have 34A total power
i have a 9500gt right know having no problems at all with it
here is my whole system
Amd Athlon 620 x4 2.6ghz OC 3.25
3GB of ram
320GB hard drive
40GB hard drive
5 case fans
asus m4a785-m
dvd-rom
im more worried about the amps then the wattage
yeah i realy want this card so i can play games better.
80 plus certified
DUAL 12v rails
+5v 20A
+3.3v 20A
+12v1 17A
+12v 2 17A
-12v 0.8A
+5vsb 2.5A
3GB of ram
320GB hard drive
40GB hard drive
5 case fans
asus m4a785-m
dvd-rom
