Sign-in / Sign-up
Audio bit depth and sampling rate questions
  • Homebuilt
  • Connection
  • Audio
  • Systems
Last response: in Systems
May 23, 2010 6:33:21 AM
Hi I just need someone to clarify the supported bit depths and sampling rates for both dolby digital live and DTS connect as I had a funny problem where I couldnt enable either under my encoder settings on my x-fi titanium sound card this morning when I turned my rig on - got a error saying the audio format is not supported. The only thing I had changed the day before was the bit depth to 24bit and sampling rate to 96khz and when I changed it back it made no difference, had to do a clean driver install to fix it.
Wiki seems to think DDL is limited to 16bit/48khz? and DTS connect to 24/48, Is this correct? Because I have the option to run 24/96 when either is enabled.
Thanks in advance.
ps sorry if this is in the wrong section
EDIT - should have said have googled this a bit and neither dolby or dts's site had info I could find.
More about : audio bit depth sampling rate questions
a b B Homebuilt system
May 23, 2010 6:59:20 AM
Check out the audio section.
m
l
