Help, building a new PC
im thinking of building a new pc, not for HARD gaming, im planning this configuration because my budget is strict....
AMD Phenom II x4 955 BE 3.2Ghz
Nvidia GTS250 1gb DDR3
4GB RAM DDR3
Motherboard that could support all this....
i have a 800w power supply yet, so dont add it to the "cart"
ignore the rest: cd/dvd burner.....
if its not so good can you tell me a configuration that fits in 550-600€, im fron Spain, and forgive my english errors... THANK YOU!! i like to play some "today" games but not at "ultra-mega-super" high settings.... high on decent FPS.... thank you again!!!!
3 answers Last reply
More about help building
  1. Okay, here's what I have:
    Phenom II X4 955 BE
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674&cm_re=phenom_ii_x4_955-_-19-103-674-_-Product
    MSI 790X-G45 mobo
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130249&cm_re=790x-_-13-130-249-_-Product
    NZXT Lexa S Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146060&cm_re=nzxt_lexa-_-11-146-060-_-Product
    G.SKill Ripjaws DDR3 4GB + GTX 470 Combo
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.401816
    Since you don't need peripherals, and I'm assuming that includes the OS, then this will be great. If you need an OS, just take off the RAM and GPU combo and add this:
    G.SKill RAM (same as above) + XFX Radeon HD 5850
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.400342
    Windows 7 Home Premium 64-bit
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754&cm_re=windows_7_home_premium_oem_64-bit-_-32-116-754-_-Product
    That's pretty much everything, since you don't need a power supply or peripherals, I didn't include them, and this is what I could come up with.Option 1 (without OS) comes out to 563€, and Option 2 (with OS) comes out to 626€, since there really aren't any DirectX 11 cards between that that are worthwhile.
    Hope this helps, and good luck with your build.
  2. for 20dollars more the 470 is a no-brainer. And thats a very god build btw nothing to add
    4GB RAM DDR3
    hey man,,, Newweg.com sells i Spain?? thanks for the info and links,.. but i didnt heard about newegg in Spain :( anyway thanks alot!!
New Build Configuration Systems Product
