Sound Card not detected
Last response: in Components
Related ressources
Windows sometimes fails to detect the default playback device automatically.. Try doing it manually.. Right click on the volume icon on the task bar and select playback.. Click on speakers and select properties.. If your device is shown listed in the drop down menu then select it and click apply.. Do the same for microphone..
Alternatively, run dxdiag and click on the sounds tab.. Check if your device is listed.. Run windows update and click on search for updates.. Windows will gather information available on any updates which are available for any of your devices or software.. It'll list drivers regarding your sound card too (if required and/or available)..
Thanks for you helpful reply Emperus. I tried everything you said, to no avail. It is still not detecting it. I am driven to the conclusion that this is a bad sound card. It is about 5 years old. But it also could be the PCI slot, but I do not have another one available due to my 5770 covering up the alternate PCI slot.
Ask the community
