S stbdtack Distinguished Mar 1, 2010 2 0 18,510 Mar 1, 2010 #1 Hello, Is it possible to buy a wired router that does not (NOT) simultaneously emit a wireless signal? If so, what is it (are they). Thanks for the help.
K kaa0653 Distinguished Dec 31, 2009 219 0 18,710 Mar 1, 2010 #2 Try something here... http://www.newegg.com/Store/SubCategory.aspx?SubCategory=28&name=Wired-Routers Additionally, every wireless router I have worked with has had the ability to shut off the wireless features. Upvote 0 Downvote
eibgrad Splendid Feb 16, 2010 3,373 2 21,465 Mar 1, 2010 #3 A wired router doesn't produce a wireless signal. Upvote 0 Downvote
S stbdtack Distinguished Mar 1, 2010 2 0 18,510 Mar 2, 2010 #4 Thanks. Found exactly what I needed on NewEgg.com. Upvote 0 Downvote
