Solved
Power
can the Nvidia 9800GT( 2 x 6-pin) be configured on a GIGABYTE Power Supply Superb 550W
Gigabyte:http://www.gigabyte.com.tw/Products/PowerSupply/Products_Spec.aspx?ProductID=2795
Nvidia:http://www.nvidia.com/object/product_geforce_9800gt_us.html
8 answers Last reply Best Answer
More about power
  1. Best answer
    Most 9800GT have only one power connector. But to answer your question the PSU is big enough for the card. If the card has 2 connectors you would need a molex to 6 pin adapter for one of the connections since the PSU only comes with one 6+2 connector.
  2. so answer ......yes or no??
  3. Yes, it should run fine.
  4. Best answer selected by dead_95.
  5. rolli beat me by 23 seconds...pathetic ;~;
Nvidia Power Supplies Gigabyte Power Graphics
