Alrite, yes i know this question is asked a lot, but i also know that every power supply is different, and every build as well, so. . .
I have a Thermaltake Silent Purepower 480W PSU.
My current build is housed in a case with 8 fans (thats including the CPU fan) all at 10cm diameter. It has a generic DVD drive, one 500GB HDD, and one 1TB HDD. It has a GA-g41m-es2l mobo, and a pentuim e5200 @ 3.3Ghz (OC'd, but no voltage increase compared to standard).
Now heres the question:
I have a 8400GT gfx card, being replaced with an ATI HD5770. Now, the power supply has no 6-pin connector for PCI-e cards (which i need).
Will my power supply cope with installing this card, and do i get an adapter for the gfx card; OR should i just buy a new PSU?
Cheers for the help
Cheers for the help
