Gaming Rig Parts Advice
Last response: in Systems
May 25, 2010 5:38:12 PM
Hello guys. After many years of buying brand rigs like gateway and dell and putting in better components i've decided to build my own system like I did many years ago. The system is mainly designed for gaming. I mainly play WoW and SC2 and don't need anything crazy but I do want a system that will last for a while and will play most games out there smoothly. Here is my list of parts.
Case - Coolmaster Haf 932
Power Supply - Corsair 850watt
Mobo - Asus Rampage Extreme II
CPU - i7 920
Heatsink - ?
Additional Fans - ?
Hard Drive - ?
DVD Rom - ?
RAM - Corsair Dominator 6gig
Video Card - Asus HD 5850
Those are the main parts I'm concentrating on. I would like the CPU to be as quiet as possible without loosing any performance.
May 25, 2010 5:54:59 PM
Fill out form in sticky, link in my sig.
m
l
May 25, 2010 6:01:00 PM
APPROXIMATE PURCHASE DATE: will purchase after I pick all parts
BUDGET RANGE: around $1500
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: mostly gaming
PARTS NOT REQUIRED: monitor, keyboard, mouse
PREFERRED WEBSITE(S) FOR PARTS: i prefer newegg
COUNTRY OF ORIGIN: connecticut, us
PARTS PREFERENCE: above i listed a few parts I really like
OVERCLOCKING: Maybe if needed
CROSSFIRE: Maybe in future
MONITOR RESOLUTION: 1920x1200
m
l
May 25, 2010 6:31:37 PM
Case - Coolmaster Haf 932 922 - imo no point going full tower unless u really want it
Power Supply - Corsair 850watt - works for me, i assume the TX for price
Mobo - Asus Rampage Extreme II gigabyte ud3r - best price for nice mobo, if u want to go asus rampage, get the extreme III (3) but not worth the money at ur budget
CPU - i7 920 930 - basically the same except the 930 is more recent, a leetle beet higher clock (2.66 vs 2.8 approx.?) and only 9 dollars more
Heatsink - unless u plan on big overclocking go with the $40 $25 hyper 212+
Additional Fans - not necessary, up to u
Hard Drive - 7200.12 1 tb or a spinpoint f3 1tb (but its out of stock at newegg.com)
DVD Rom - some cheap $20+ dollar dvd drive
RAM - Corsair Dominator 6gig go with some gskill sticks for better price for performance edit: these r nice gskill sticks too
Video Card - Asus HD 5850 with these changes u can get a.... 5870!!
if u were doing more intensive gaming than sc2 and wow then i would suggest lowering the cpu and mobo to a p2x4 955 (AMD) with some decent ~$120 mobo to try and squeeze in a 5970
m
l
May 25, 2010 6:42:45 PM
Will the system last a while meaning will it play games at pretty good setting in future? I just really like Asus mobo because it is so easy to OC and i'm not too familiar with it so if software makes it easy im all for it.
m
l
May 25, 2010 6:42:51 PM
CPU/HSF
i5-750 and CM Hyper 212 Plus $220
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
MOBO/PSU
ASUS P7P55D-E LGA and 750TX $255 w/ $20 MIR
not a xfire board, but with a 5970, don't need xfire, nor will the 1156 really benefit from more than that anyway.
RAM
Ripjaw DDR3 1600 7-8-7-24 $110
Case/HD
HAF 922 and 7200.12 $120
GPU
5970 $700
Optical
LG $20
OS
Win 7 Premium 64 bit oem $99
Total $1528 before shipping and $20 MIR
$100 less if you don't need OS.
edit: Fixed it actually right this time!
m
l
May 25, 2010 6:49:42 PM
Will this setup be overclockable? The room that the computer is in gets very hot in the summer and when I play games for hours my previous rigs have overheated a lot. Will setup above have heat problems?
m
l
May 25, 2010 6:54:54 PM
That depends on ambient. My i5-750 with that HSF doesn't get above 49C on load, with 27C ambient.
I don't remember exact OC setting but i think it's 3.6ghz at 1.28v
m
l
May 25, 2010 8:19:23 PM
if u speak of SC2, WOW, D3, etc. then yes it will last a while.
asus and gigabyte for the most part have a pretty equally high standing on average.
in terms of overclocking, people seem to think gigabyte stuff is better, but the asus stuff is more noob friendly
m
l
May 25, 2010 9:09:39 PM
so the system banthracis listed is best gaming rig possible for around 1500? I'm just a little hesitant on spending 700 on a GPU. wouldnt it be better to get 2x 5850 in crossfire? Or spend less on GPU and get better processor mobo..etc..
m
l
May 25, 2010 9:29:47 PM
Well 2x 5850 works, but also requires a xfire mobo, which is $40 more. Also, the 5970 is a weird card, it's 2 5870's, but underclocked to 5850 speeds. It's performance is actually smack in the middle btwn 2 5850's and 5870's.
Course you could just OC it.
Honestly, you could also get away with getting the xfire version of teh Asus mobo
1 5870 and save $280 ish and use that money towards a SSD like the Intel X25-M g2 80 GB, currently $195. You could also play around with combo's a bit and save some more money as the 5870's have some nice combo's. Also, new mobo combo opportunities as well.
Ex. this 5870 mobo + the RAM combo
That build is just the best gaming performance you'll get out of $1,500 atm.
CPU wise, you're not gonna need more than the i5-750 and in fact, anything more is really a waste for that purpose as it's not gonna bring more FPS to the table.
m
l
May 26, 2010 1:14:01 AM
thank you very much for your help Banthracis. I will be buying all the parts that you listed including the 5970. I figure with that card I can last a while and play most of games in near future. Do you think I should overclock and what do you recommend for settings?
m
l
