Cable Management really matters with Fermis
April 22, 2010 7:46:28 PM
Alot of people in the Giveaway thread have asked me to post some pictures up of my system. I decided to take a break from studying and do just that.
What I did realize through this process, is that both my CPU, and especially VGA temps went down. (Yes I already knew from before cable management wasn't just for looks but also for good airflow, but with such little fans I have in the system compared to before I didn't think it would matter.
Anywho take a look:
CPU before hover 39/40 @ idle
After: 35/36 (Both in C) @ idle
VGA 2 480s sli @ idle 64/65 (first card) 60/61 (2nd)
After: 59/60 54/56
CPU I wasn't too excited about....but VGA WOW...
Anyways
Here is my rig: (Specs in SIG)
April 22, 2010 7:52:03 PM
Darn 60 degrees Celsius idle! What the hell! Is that a barbecue or something?
Nice rig tough.
m
l
April 22, 2010 7:57:01 PM
My 285s in tri sli idled around 60 so its not a big deal for me. lol
m
l
a b U Graphics card
April 22, 2010 8:09:26 PM
Nice. Wow those cards are close together though. I'm amazed with how low temps are with them that close. Perhaps is that why they have the fan hole in the PCB?
m
l
April 22, 2010 8:16:01 PM
I assume so:S either way I'll see these at 35-40 idle when I get back...with Water cooling.
m
l
a b U Graphics card
April 22, 2010 8:18:20 PM
Which way is the air flow on your H50 push/ pull ?, know I should be able to tell , but forget my reference point ,at the moment.
m
l
April 22, 2010 8:26:52 PM
push pull yes:)
m
l
a b U Graphics card
April 24, 2010 5:57:23 PM
Awesome cable management L1qu1d. I need to work on mine for sure. You and I appear to have the same case, except mine is the black version. Though I had to take the side fan out so my Xigmatek HDT-S1283 would fit.
m
l
a b U Graphics card
April 24, 2010 7:45:06 PM
Looks fairly clear man.
m
l
April 25, 2010 3:17:53 AM
those cards are almost scary that close together.
m
l
