I installed Windows 7 on my new SSD. When I turn on my computer, the Windows Boot Manager comes up. It asks to me to select from two instances of Windows 7 to boot. One is Windows 7 on my new SSD, the other is Windows 7 on my old HDD. I select my Windows 7 on my new SSD as the boot option, and it boots up fine.
After this, I tried to disconnected the HDD and I just left the SSD connected. This time, when I turn the computer on, I get the "reboot and select proper boot device" message. Why am I getting this problem?
I'll list all my specs, incase it helps. I'll also post a shot of the disk management screen, so you guys can check it out.
http://i.imgur.com/MLF22.jpg
SSD: Crucial 256 GB m4 2.5 SSD SATA 6GB/s
HDD: Not sure about HDD specs, but it's a bit more than 500 GB and I connect it with a sata cable
PSU: Cooler Master RS550-PCARE3-US eXtreme Power Plus Series 550W ATX12V V2.3 Active PFC Power Supply
RAM: 4 x 4 GB Corsair Vengeance DDR3 1600 MHz DDR3
CPU: Intel Core i7 2600K Processor 3.4 Ghz 4 Core LGA 1155
MOBO: ASRock z68 extreme4 gen3 lga 1155
