I have a amd x4 965 black edition cpu, Gigabute 890 FxA-Ud5,XFX 5850,crosair4gb ddr3 ram,ST2410 dell monitor,and a psu coolarmaster GX550w ,is it a sufficient power supply for the entire system.thanks
you should be OK. cooler master does have a lot of bad PSU and would not be my first choice of a PSU brand. since you already own the PSU, i would use it and just keep an eye on it.
Thanks for the reply,I would also like to know which other psu are considered best ,I was also considering changing my psu from coolarmaster gx 550w to coolarmaster to a GX 650w ,should it be considered .
I have narrowed down to a corsair HX 620w or a corsair HX 650w for my current requirnement and possible small future upgrade,Are they good PSU's I am also considering a APC ups of 1100va/660w for the both the above models will it do the job, my max load will be around 75 % on either of the psu's.Thanks.
Extract from: http://www.overclock3d.net/reviews/power_supply/corsair_hx650w_650w_atx_psu/5
The Good
- Stable voltages across all rails
- Reasonably high efficiency with an average of around 86%
- Great looks and tasty modular cables
- Excellent ripple suppression
- Max output around 720w
- All Japanese caps.
- 7yr warranty!
The Mediocre
- Not quite as efficient or stable as the HX750w or HX850w
- Didn't like one of the cross-load tests (but as I've said already 3 times, its not likely to be reproduced in real world)
