Finally got around to ordering my new (first) build and after getting everything together the board would not post (everything powered on, drives, board, fans, GPU, case, etc.., just no video and no beeps), troubleshot it and ended up call Asus tech support and they told me to RMA the board and if that does not work, I should RMA the CPU. Sent it out and am wait for it's return but now I am starting to second guess myself on compatibility mainly because after doing some more research my specific processor model number is not on asus's site for compatibility with their board (the 635 is, just not the ADX635WFGIBOX model) and I'm under the assumption that a board wont post if the CPU doesn't jive. So, can I get some feedback from all ya'll.
Here is what I got:
AMD Athlon II X4 635 Propus 2.9GHz Socket AM3 95W Quad-Core Desktop Processor Model ADX635WFGIBOX
ARCTIC COOLING Freezer 64 Pro 92mm CPU Cooler
ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard
HIS H577FM1GD Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Rosewill Xtreme Series RX750-S-B 750W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire Ready, Active PFC "Compatible with Core i7, i5" Power Supply
Rosewill Wind Knight Gaming ATX Mid Tower Computer Case with pre-installed 2x 120mm Fan, Support up to 1x 140mm top fan, 2x 140mm side fan, 1x 140mm front fan, 1x 120mm rear fan
Here is what I got:
