I'm thinking of building a relatively cheap web server for personal use. I'll be looking into parts myself but could use some guidance if people have anything to add.
Here's what I'm thinking:
cpu - minimal/average cpu. don't think I'm going to need crazy processing power for anything. thinking of a 2ish ghz single core
■AMD Sempron 140
■Intel Celeron 430
memory - thinking around 1GB
■Kingston ValueRAM 1GB
power - I want to try and minimize power consumption as much as possible, as I'll be running the server constantly
motherboard - I'm gonna want a bios that can be configured to boot w/o a monitor/keyboard and a minimal integrated video chip. other than that, pretty much going for minimizing cost
■ASUS M4N68T-M AM3 Micro atx (if I go with the AMD cpu)
video - like I said, minimal integrated chipset. I'm planning on using a monitor only for the install and for when I can't access the server through other means (ssh)
sound - don't see any reason to have sound
case - I want a smallish/medium sized case if possible, unless it would cause heating issues
■APEX TX-381-C Black Steel Micro ATX
fans/cooling - relatively important, trying to strike a good balance between quiet and heating-prevent. quietness may take some precedence as I'm going to probably be putting it in our basement where the rest of my family spends time, but as I'm going to be running it constantly I'm a bit concerned about heating
■ARCTIC COOLING CPU Cooler for the AMD cpu, if I decide to not go with AMD's heatsink. supposed to be ultra quiet, but if AMD's heatsink isn't too bad I might just use that instead of spending $30 on this
hdd - prob gonna go for 100gb or something, not going to be storing huge amounts of files, and if the need ever arises I can always upgrade
■Seagate Barracuda 7200.11 160GB
that's everything I can think of. any input is appreciated.
also, looking for 64bit support
price so far: $214 (w/ the amd cpu and w/o a psu). $184 if I decide to not buy the separate heatsink
■AMD Sempron 140
■Intel Celeron 430
