Hello all.
I'm building a new pc and I'm going to use the intel i5 2400 processor. What I'm looking for is a good motherboard for the i5 2400 processor.
The graphic card will probably be a Radeon HD 5850 (don't know if I will have the money for gtx 560). Crossfire and SLI is important because I will probably add a second graphic card later.
Something like a budget/middle/high end alternative.
Also it would be great if you could enumerate the characteristic that I should look when choosing the motherboard.
Thanks for you time.
