Solved
Maintenance of Liquid cooled Case
Hello
I am thinking about possibly going the liquid cooled route but I have 2 questions right of the start
1) how much maintenance is required to maintain a liquid cooled case
2) how quiet are liquid cooled cases
6 answers Last reply Best Answer
More about maintenance liquid cooled case
  1. I don't think there are really any water cooled cases, just a water cooled system in a case which can mount a radiator.
    Liquid cooled cases are quieter generally, although it depends what you have cooled.
  2. Sorry I meant liquid cooled systems, and I am looking to cool my CPU
  3. Best answer
    Maintainance really depends on you man,
    But you will have to drain the system at least twice a year to change the liquid and top up on anti-fungal, and although W/c technically should be 'silent' you still need fans to cool the radiator so make em big and slow ones if you want a quieter system
    Moto
  4. Best answer selected by redwing3139.
  5. Thank You
  6. No problem, Thank you for best answer :)
    Moto
Power Supplies Cases Components
