New System Build. Thoughts?
Hello Team,
I have been spending a lot of time looking through boutique builders, and get apprehensive just shy of pulling the trigger. I always hop onto NewEgg and 'build' the same system to find that I am spending $500 - $1000 more than building it myself. [/what everyone already knows]
Here is what I am thinking:
Usage: FPS gaming at 1920x1080 (need a new monitor as well)
CPU will be clocked to a minimum of 3.8Ghz
Still trying to decide on 5870 or GTX 480. Will likely get a second card in future.
Heart isn't absolutely set on the Obsidian 800D, but lots of good reviews.
Plan to liquid cool within a year.
Newegg Total With Shipping: $2007.79 ($1977.79 after Mail in Rebates)
Case: Corsair Obsidian Series 800D CC800DW Black Aluminum
Motherboard: EVGA 141-BL-E757-TR LGA 1366 Intel X58 ATX X58 SLI LE
CPU: Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core
CPU Cooling: CORSAIR Cooling Hydro Series CWCH50-1 120mm
GPU: EVGA GeForce GTX 480 SuperClocked 1536MB GDDR5
System Memory: CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 1600
Power Supply: CORSAIR TX Series CMPSU-950TX 950W ATX12V
Hard Drive: Intel X25-M G2 2.5" 80GB SATA II MLC Internal Solid State Drive
Optical Drive: ASUS 24x DVD Writer LightScribe Support - OEM
Internet: D-Link DWA-556 PCI Express Xtreme Desktop Adapter
Other: FREE DIAMOND ATI TV Wonder HD 650 Combo Tuner PCI-E
Thoughts?
5 answers Last reply
More about system build thoughts
  1. I would go with a HD5870, and then crossfire down the road, as it stands now, ATI has nVidia beat on the performance to value ratio. Also, the new fermi chips get really hot and use a lot of power.
    Upgrade to the i7-930, its the new standard
    The Hydro H50 is kind of risky because budget watercooling is asking for problems. I would recommend the CoolerMaster Hyper 212+ until you upgrade to real water cooling. It has been reviewed very well and is very popular.
    I think G.Skill RAM is going to be a little cheaper, the dominators really aren't worth the added price.
    Make sure the SSD you get is the second generation (G2)
    You will probably need a storage drive, I would suggest the Samsung Spinpoint F3 500GB/1TB HDD.
    Thats a great PSU, but a little overkill, you would be set with the 850TX.
  2. nVidia vs ATI:
    I see the same Pro vs. Con on these. 480 is faster then 5870, slower then 5970.
    1.5 GB on 480 vs 1.0GB on reference 5870 but doesn't make a difference.
    5870 runs cooler, draws MUCH less power at idle.
    480 has CUDA and PhysX though, which lean me their way.
    Charts also show 480 scales better in SLI then 5870 in XFire.
    Am I missing anything here? If the 5870 is the better choice... I will go that route.
    Can the H50 support a 3.8Ghz overclock on an i7?
    The Ram comes in a combo with the CPU [$280+$270=$550 -$35=$515]. So the combo essentially makes the ram cost $235. Lowest priced 3x2 [6GB] ram I can find is $170. Link to better ram option?
    Thank you for noting the second Gen Intel, I was reading up on the differences last week. I actually have an old 74gb Raptor that will be my storage drive. All that I do is play 1 or 2 games, surf the net.
    What would be required as far as power supply to do dual 870s? Dual 480s?
  3. [1] You mention that you'll be gaming at 1920 X 1080. Now a 5870 is more than able to play any game maxed out at that resolution (maybe except metro 2033, which is just poorly coded & buggy anyway). In fact, if you add a second 5870 down the road, the combination of both would be absolute overkill for 1920 X 1080. In that case, you could consider eyefinity & add a couple of more monitors. Or you could get a single 30" 2560 X 1650 display.
    In conclusion: you don't need the hotter & power hungry gtx 480 for gaming at 1920 X 1080, where a single 5870 would be adequate. Even if you add more monitors or upgrade to a higher resolution display, adding a second (even third) 5870 would do the job.
    [2] With regards to CUDA & PhysX, how many of the games out there really take advantage of that? That's just an Nvidia gimmick.
    [3] You could consider this RAM : Gskill - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
    Very good value for money.
    [4] With the money saved on RAM, get the i7-930.
    [5] The Corsair 950TX is more than enough for 2 5870s. An 850 will work just as well.
    [6] One pointer: The EVGA board you listed doesn't seem to support crossfire. You might want to consider this:
    Gigabyte GA EX58 UD3R - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
    Great board.
    Yes it can.
  4. You didn't list purpose of build so I'll assume gaming. Here's basically the optimal gaming build ATM in terms of price/performance ratio.
    CPU
    i5-750 $195
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
    MOBO/PSU
    ASUS P7P55D-E LGA and 750TX $255 w/ $20 MIR
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.391967
    not a xfire board, but with a 5970, don't need xfire, nor will the 1156 really benefit from more than that anyway.
    RAM
    G SKill Eco DDR3 1600 7-8-7-24 $120
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321&cm_re=g_skill_eco-_-20-231-321-_-Product
    Case/HD
    HAF 922 and 7200.12 $120
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.400950
    GPU
    5970 $700
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125303&cm_re=5970-_-14-125-303-_-Product
    Optical
    Lite on $20
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
    HSF
    CM Hyper 212 Plus $29.13
    http://www.amazon.com/Cooler-Master-RR-B10-212P-G1-Universal-Heat-Pipe/dp/B002G1YPH0/ref=sr_1_1?ie=UTF8&s=electronics&qid=1274885340&sr=1-1
    Total:
    Total ~$1440 before shipping and $20 MIR
    Shipping is only $10 to NYC (almost everything is free ship).
    Now from here on the extra
    Monitor
    Hanns G 23" 1920x1080 5ms $159 w/ promo code EMCYSNW32. Pretty insane deal right there. Hanns G is a display maker for Dell's LCD's, so they're a very good, if little known company.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824254045&nm_mc=EMC-IGNEFL052810&cm_mmc=EMC-IGNEFL052810-_-EMC-052810-Index-_-MonitorsLCDFlatPanel-_-24254045-L0A
    Mouse
    Mx518 $40.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
    Keyboard
    Saitek Eclipse $28.50
    http://www.amazon.com/Saitek-Eclipse-Backlit-Keyboard-PZ30AUR/dp/B000EA2HD4/ref=sr_1_4?ie=UTF8&s=electronics&qid=1274885240&sr=1-4
    SSD
    Intel X25-M 80 gb $195
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820167016&cm_re=x25-m-_-20-167-016-_-Product
    Total with extras: $1864.50 before MIR and shipping
    Take extra money and take GF out to a nice dinner since you'll probably be neglecting her for a while after you get this :D
    Edit: Swapped to G SKill eco kit, as it's same price as ripjaws now. ECO kit is lower voltage ripjaws basically.
  5. Couple other notes on your build.
    1. Liquid cooling doesn't compare to big air until ~$500 worth of parts.
    2. Pre-packaged kits like the H50 are louder, and worse performing than good air.
    3. PhysX is basically dead. CUDA has nothing to do with gaming... it's for massive parallel computing, especially benefiting floating point calculations.
    4. Raptors are equaled in performance by the Samsung spinpoint F3's which are are fraction of the price for much more space.
    5. Case is your choice, but honestly, I've never spend more than $150 for one. A HAF 922 is really a the top deal ATM.
    6. You can also consider spending another ~$180 and get this Asus MOBO
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641&cm_re=asus_usb_3-_-13-131-641-_-Product
    and g skill Pi RAM/i7-930 combo here
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.399766
    can play around with some other combo's too.
    The only reason I don't really recommend is that the 5970 will be all you'll need at 1920x1080 until next gen consoles come out, 2014 earliest. As a result, don't really need the 1366 platform. However, if you ever wanna eyefinity, then you'll need to got he 1366 route, as 1156 can't really use more than the 5970.
New Build Systems Product
