Archived from groups: alt.games.tombraider (More info?)
..After playing all other Tomb Raider games decided to play Tomb Raider the
original. Problem below not mentioned as bug on Stella walkthrough.
Following Lara gets stuck on crevice just before start of bit below door.
She will not go any further. Therefore cannot get essential key. Can
anyone help
LEVEL 9: TOMB OF TIHOCAN
ROOM WITH LION, GORILLAS & SPIKES: Stay on the step at water level until
you've killed the lion lurking in the room. In the U-shaped passageway on
the side of the room opposite the spikes you'll find a switch. Use it to
open a door above and awaken 2 gorillas. Return to the spike room and climb
into the alcove and onto the step. From here you should be able to kill the
apes. (There's also a save crystal here in the PSX game.)
When they're dead, take a standing jump to grab the floor above and pull up.
Cross to the gap above the spikes. Take a standing jump to grab the crevice
to the left of the doorway and traverse right until you can pull up. Enter
the room and pick up a large medipak and a GOLD KEY. Take a standing jump
from the doorway over the spikes. Then drop down into the room below.
